Engine cranks but will not start
198,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
MAMASHARKX2
Okay, i have replaced fuel pump, starter, battery, and ignition switch. car cranks but still wont start. Not sure what to try anymore. would anyone have any ideas as to why it won't start?
Oct 24, 2019 at 10:59 PM
Good morning,
Did you check for spark to the plugs?
When you crank the engine, does the tachometer move up on the dash?
Can you hear the fuel pump run when you turn on the key?
Oct 25, 2019 at 1:42 AM
MAMASHARKX2
Yes to everything and I even checked the timing chain and it's all lined up.
Nov 1, 2019 at 4:44 AM
What is the fuel pressure?
What is the compression?
Nov 1, 2019 at 5:06 AM
