After replacing the low fuel pump the engine will not crank?
266,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JAMES ALLEN WARE
I just changed the low-pressure fuel pump on my vehicle listed above CX and now my vehicle won't turn over. At all! No cranking whatsoever. Just makes a clicking noise. Help please it's the only vehicle I have, and I am learning as I go because I can't afford to take it to a shop.
Sep 12, 2024 at 12:32 PM
  • 55,746 POSTS
Yep, the battery sounds like it needs replacement, here is a video that will help you find out for sure:
https://youtu.be/6YRW8fyNudY?si=PcYklmYGplxdED0i
Here is how to change the battery out. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 13, 2024 at 2:19 AM
