When i turn the key i hear a loud whining noise but car will not start
100,000 MILES • 2.0L • TURBO • 2WD • MANUAL
KHEALY995
when i put the car in gear and rock in back and fourth it will then start . can you help me to fix this problem? thanks
Dec 31, 2019 at 11:02 PM
Is there any way you can get a recording of the noise? It sounds like the starter is not engaging and when you rock the vehicle it moves the flex plate and allows the starter to engage. However, the starter has a tapered cut gear so that it spins the flex plate as it engages to ensure it is able to mess. So this doesn't seem to make sense but I am not sure what else this could be. Hearing the noise will help identify what it could be. Thanks
Jan 1, 2020 at 9:30 AM
