So here is my problem: Car runs fine and drives fine. But i cannot start this car unless i press the gas pedal while cranking it over. I have done everything i can think of. Spark plugs/wires, cap and rotor, fuel filter/pump, fuel injectors, MAF sensor, TPS sensor, cleaned throttle body, new battery, o2 sensor, PCV valve, ignition coil that sends spark to the distributor. I've replaced all of these things and nothing. Some of these needed replacement anyways, but some of it was probably fine. I would really appreciate some insight. Thanks
Oct 5, 2021 at 9:09 AM
