Manual starting crank installation instructions needed
1986 JEEP CJ7
140,000 MILES • 4.2L • 6 CYL • 4WD • MANUAL
BMOREFERRIS
Can you send a link for how to get a manual starting crank installed?
Mar 25, 2021 at 10:10 AM
I-SMOGEM
  • 118 POSTS
Hand-cranking was a method commonly used to start early automobile engines, but it was inconvenient, difficult, and 'dangerous'. The behavior of a gasoline engine during starting is not always predictable - the engine could kick back, causing “sudden reverse rotation” of the crank handle. Even a simple backfire could result in a broken thumb, and it was possible to end up with a broken wrist, a dislocated shoulder or worse when hand-cranking. Over the years, larger and larger engines with higher compression ratios made hand-cranking even more physically demanding (if not impossible) and severely dangerous.
I couldn't find any information on aftermarket hand-crank systems, or how to design one. The likely reason is they could be held liable for injuries.
Glenn
Mar 25, 2021 at 1:30 PM
