Will not stay running
2,000 MILES • 2.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
STANLEY CHIPETEME
Good morning, my 2kd haice after changing the pistons and the rings it can start but go off after a minute and it does not have power. Please help. what could me the problem?
Apr 10, 2021 at 9:54 AM
  • 110,248 POSTS
First, this vehicle isn't offered in the US, so I have little technical information on it. However, I will try my best to help.
First, does it start right back up after it stalls? Also, have you re-checked the ignition timing to make sure it is correct?
Here is a link that explains the most common causes of a stalling issue at idle. Hopefully, there will be something in it that helps you.
https://www.2carpros.com/articles/stall-at-idle
Also, have you checked fuel pressure? Could the catalytic converter be plugged? Take a look through this link and let me know if it seems to mirror what you experience.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Apr 10, 2021 at 3:43 PM
