When trying to start the car it would make a rapid clicking noise and not even turn over the engine?
10,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
MR.GRAPE1971
  • 5 POSTS
I have replaced the battery with a brand new one. Every once in a great while when it starts up and I drive it, it will stall on me usually when slowing down and sometimes misfires.
Dec 28, 2024 at 2:28 PM
  • 55,694 POSTS
I would start by checking the ground to frame/chassis connection from the battery, you must have two grounds one to the block and the other to the chassis. Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. Please start a new question for the misfire and stalling, let me know what happens.
Dec 30, 2024 at 2:20 AM
MR.GRAPE1971
  • 5 POSTS
This is the video of the clicking noise when trying to start the engine.
Dec 30, 2024 at 7:03 AM
  • 55,694 POSTS
This sounds like the flex plate is broken and the starter is just spinning it without cranking the engine, or the starter is bad. I would remove the starter and then use a large prybar to see if you can move the flex plate without the engine turning. Thanks for the video, it helps. Please let me know what you find. Happy new year!
Dec 31, 2024 at 3:27 AM
MR.GRAPE1971
  • 5 POSTS
We were able to take the starter out and find it was indeed broken with no fault to the flex plate. The alternator then went out, so we got a new one put in. Then the car wouldn't start on me again when I was out shopping and turns out I bought a refurbished starter, and it died one me, so I bought a completely new one and the car has been running great ever since. Thank you!
Jan 20, 2025 at 10:28 AM
  • 55,694 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Jan 21, 2025 at 2:31 AM
