starting and boosting problem
250,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
NAZEER COLLINS
1. Vehicle does not start when cam sensor is plugged in.
2. disconnect the cam sensor, motor starts and idles.
3. connect cam sensor, motor shuts off.
4. No cam sensor vehicle mobile in limp mode.
History.
motor overheated and busted the cylinder head.
New head fitted
new oil pump.
motor re done (rings, bearings).
timing set again, both front and clutch flywheel.
no electrical problem diagnosed by Nissan dealer.
Sep 1, 2019 at 5:15 PM
SCGRANTURISMO
  • 4,897 POSTS
Is this the stock engine that came in the vehicle? My reference guides show either a 4.0L or 5.6L engine configuration options for your year, make, and model vehicle.
Thanks,
Alex
2CarPros
Sep 3, 2019 at 2:48 AM
