it will not turn over and it sounds like there is no air pressure getting to the engine.
Jul 16, 2017 at 9:06 AM
SATURNTECH9
✓Experienced Mechanic
So does it crank and not start? Or no crank no start?
Jul 16, 2017 at 10:16 AM
COY LINDERMAN
MEMBER
it cranks, but it will not turn over.
Jul 16, 2017 at 1:01 PM
SATURNTECH9
When you say it cranks but will not turn over? So the starter spins the engine over normally, but it just will not start? Also, with the key in the run position is the security light on solid or flashing on the dash?
Jul 16, 2017 at 1:49 PM
COY LINDERMAN
MEMBER
no it is not on. i think it might be the o2 sensor. would that cause it not to start?
Jul 16, 2017 at 11:59 PM
SATURNTECH9
No, a o2 sensor is not going to cause it not to start. I need to know does the starter spin the engine like normal when trying to start it? Or does the starter not spin the engine at all while trying to start it?
Jul 17, 2017 at 12:08 AM
COY LINDERMAN
MEMBER
the starter does spin and it acts like it wants to start. it does sound like it is miss firing.
Jul 17, 2017 at 12:11 AM
COY LINDERMAN
MEMBER
i really hope it is not the timing belt but what if it is the starter?
Jul 17, 2017 at 12:12 AM
SATURNTECH9
So the engine cranks over faster then normal?Also your engine has a chain not a belt but the chains still fail on those engines.
