Will not stay running
235,000 MILES
BRENDA LARADE
The car starts but will not keep running. just wondering if you would have any idea what might cause this.
May 25, 2019 at 4:59 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Does the car have the check engine light on? If it is and you don't have access to a scanner/code reader most auto parts stores have a loaner program and will rent you one.Here is a tutorial showing how to read codes:
It could also be a weak/failing fuel pump.You should perform a fuel pressure test.A tester can also be rented. Here is a fuel pressure test tutorial:
Fuel pressure should be between 35-70 psi. Hope this helps and thanks for using 2CarPros.
Danny-
May 25, 2019 at 7:01 AM
