will not start in park unless lever is put in park roughly?
60,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BORISEDDY1943
sometimes will not start in park unless lever is put in park roughly, and never starts in neutral.
Aug 21, 2022 at 8:10 AM
  • 110,251 POSTS
The neutral safety switch is actuated from inside the transmission. With that in mind, I suspect the shift cable may be somewhat out of adjustment. At least this is where I would recommend starting.
If you look below, I attached the directions for adjustment. Keep in mind, there are nylon bushings that can go bad as well, so make sure to inspect all connections.
Also, inspect the condition of the connector to the switch. Pic 2 below shows the location.
See pic below.
Aug 21, 2022 at 2:10 PM
