My engine is not starting?
157,000 MILES • 1.6L • 4 CYL • 4WD • AUTOMATIC
SKYCHI
  • 5 POSTS
Car will not start and when i turn the car on there is a clicking noise from behind the glove compartment. What could it be not making it start?
Feb 24, 2018 at 11:15 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I am assuming that is the PGM-FI Main Relay which is shown in this diagram.
It runs the fuel pump.
Can I assume the starter is cranking over but the engine just will not start?
I will assume your answer is yes, so first check the fuses #31, #13 in the under dash fuse box and #44 in the under hood fuse box. If they are all okay, try a new PGM-FI Main Relay.
Feb 24, 2018 at 11:42 PM
SKYCHI
  • 5 POSTS
is this something i can/should buy myself and install myself? or should i tow it to the mechanic and have it done professionally.
Feb 25, 2018 at 1:09 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
That depends. Try what you can and if you cannot do it, then decide what to do from there. If you know how to check fuses and/or replace relays then by all means go ahead and do that. If there is something that you cannot do or need help in doing, let me know.
Feb 25, 2018 at 1:20 AM
SKYCHI
  • 5 POSTS
The black box is what is clicking and the circled item...is that the main relay?
Feb 28, 2018 at 1:51 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
They are both clicking? Have you tried disconnecting the wiring plug to each, starting with that item that you are pointing to, which appears to be that PGM-FI Main Relay and listen if the clicking goes away?
Feb 28, 2018 at 2:01 AM
SKYCHI
  • 5 POSTS
oh so the black box is the main relay ? thats the only thing that clicks when i turn the car on. Do i unplug it from where i put the arrow ?
Feb 28, 2018 at 2:19 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Yes, unplug it there.
If it stops clicking after unplugging it, go ahead and check those fuses I mentioned earlier and if they are all ok, try a new PGM-FI Main Relay
Feb 28, 2018 at 2:44 AM
SKYCHI
  • 5 POSTS
Thanks for your help but it was the ground wire under the thermostat housing wasn't on tight. tightened it and it works.
Mar 2, 2018 at 11:00 AM
  • 55,746 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Mar 5, 2018 at 5:02 AM
