Intermittent not starting issue
112,000 MILES • V6 • 4WD • AUTOMATIC
RENEE718
Will not start and throttle light comes on. sometimes it will start.
Jan 19, 2021 at 2:23 AM
This could be a couple things but that throttle light will have some codes that code along with it so that is where we need to start.
Here are some guides that will help with this issue in general however, we need those codes because I suspect we have a sensor issue that is causing this.
https://youtu.be/dCjmRL3p4Cs
Let us know and we can go from there. Thanks
Jan 20, 2021 at 9:45 AM
