Intermittent hard starting issue
130,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
JIMVESSELS
(1) key in ignition , turn to start position, it just clicks.
Repeat step (1) 2 or 3 times. Still doesn't turn starter.
Try 1 more time, clicks, starter engages, engine starts and runs.
Drive. Stop, turn off ignition. Engine starts normally .
Aug 17, 2021 at 2:25 AM
Good afternoon,
This sounds like a dead spot in the starter motor itself.
I would start by cleaning the battery cables to be sure it is not a bad connection. Otherwise, replace the starter motor.
Aug 17, 2021 at 4:46 AM
