Not starting
WILLIAM TITLEBORN
  • 1986 TOYOTA TERCEL
  • 1.5L
  • 4 CYL
  • 100,000 MILES
Car will not start. It has new whole new ignition system including distributor cap and rotor so it has spark, clean gas, but will not start at all. The timing is correct. What next?
Wednesday, October 18th, 2017 AT 8:12 PM
  • 31,937 POSTS
Do you have injection pulse? Is fuel rail pressure correct? Do a code clear and a re start attempt. Do any new codes re set? Not all codes will set a check light.
Wednesday, October 18th, 2017 AT 10:00 PM
WILLIAM TITLEBORN
Car has no computer at all carborated 4cylinder and it has pulse
Friday, October 20th, 2017 AT 11:54 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Does the engine have compression? Lets try this quick test
and this guide can help as well
Please run this test and get back to us so we can keep helping you.
Cheers, Ken
Saturday, October 21st, 2017 AT 11:14 AM
WILLIAM TITLEBORN
Yes I've already tested the car has compression
Saturday, October 21st, 2017 AT 11:17 PM
  • 31,937 POSTS
You have good compression, spark and fuel, sounds as if it is a timing problem, with No 1 at TDC timing mark is at O in front cover? And rotor is phased correctly to No 1 cyl and leads are in correct position? Are the plugs wet with fuel?
Sunday, October 22nd, 2017 AT 1:27 AM
