will not start
138,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
JAC73
Will not start. I thought it was the ignition control module but did not fix it. So I replaced the fuel pump and cap rotor wires and plugs checked all vacuum lines. I am getting fire and fuel but it will not start. I am out of ideas now thinking of either putting carburetor on it and doing away with computer or just dropping old school 5.7 in. need help very frustrated.
Jan 11, 2017 at 11:34 PM
HMAC300
  • 48,601 POSTS
scan for codes first and check resistance of pickup coil should be 400-1000 ohms have ignition module checked at auto parts. also, check resistance of coolant temperature switch should be high when cold and drop resistance as it heats up.
Jan 12, 2017 at 12:07 AM
JAC73
I have replace ignition module, but have not checked ohm's on coil and did not think about coolant temperature sensor. I had same problem on another vehicle. Thanks for responding and the information helps greatly.
Jan 12, 2017 at 12:18 AM
  • 55,721 POSTS
Hey JAC73,
Lets check to see if the engine has compression enough to run, here is a guide to hep show you what to do.
Please let me know what happens so it will help others.
Best, Ken
Jan 17, 2017 at 5:27 PM
