starting
2003 FORD F-350
110,000 MILES
DOZERDRIVER
I drove my truck to a friends house and shut it off...10 minutes later I went out and it would barely crank over it wouldn't jump . I took the batteries and had them load tested they are fine I took out the starter its fine checked the fuses none blown. The truck cranks over but just not fast enough to start the truck.
May 6, 2013 at 5:46 AM
since you provided no engine size, i assume it is a 6.0
check the ac compressor bearing for being seized as it will make the truck barely crank over. we see a lot of this in our fleet
May 6, 2013 at 9:30 AM
