Ticking sound when car is turned off
132,000 MILES
VIVIAN L. CHAMPION
The car has a ticking sound when it is turned off and it will not start again unless I disconnect the battery.
Aug 1, 2016 at 8:12 AM
HMAC300
  • 48,601 POSTS
check around where it is coming from it may be a relay and disconnect it and switch with a like relay see if it continues, if it does it may have a short in harness causing it or a module problem.
Aug 1, 2016 at 8:26 AM
