Starting
160,000 MILES
DREAMER061687
Car overheated. A radiator hose had a small hole and leaked. Replaced hose and coolant and took car for test drive. Car did well, no overheating. Returned home put car in park it had a rough idel. A few hrs later attempted to start car it wouldn't start but it. Was turning over. Checked oil no coolant in the oil noted. All spark plugs have spark(white) cleaned spark plugs. Removed coil pack and cleaned / dryed seem damp. Car continues to not start and now all of the gauges max out when trying to start the car
May 29, 2013 at 6:58 AM
CJ MEDEVAC
  • 11,000 POSTS
JUST FOR GIGGLES, DISCONNECT THE BATTERY WAIT 10 MINUTES, THEN RECONNECT IT....THIS MAY RESET THE COMPUTER
IF THIS IS A NO GO SITUATION
REMOVE BATTERY FROM VEHICLE HAVE IT TESTED AT A POPULAR AUTO PARTS STORE, USUALLY THIS IS A FREE SERVICE.
ONLY INSTALL A FULLY CHARGED OR NEW BATTERY......DON'T CHARGE IT WHILE CONNECTED TO THE CAR!
THE COMPUTER MAY BE SORTA "HUNG" ON A LOW VOLTAGE READING, THE ONLY WAY FOR IT TO RESET IS WITH A FULLY CHARGED BATTERY, AND THE CABLES COMPLETELY OFF...........JUMP STARTING WILL NOT CUT IT!
........IF YOU NEED A BATTERY...OR ANYTHING ELSE
READ THIS LINK--- THE "METHOD" MAY AID YOU ANYWAY, IF ADVANCE AUTO PARTS IS NOT A LOCAL STORE OF YOURS.........AND "A124" WORKED FOR ME YESTERDAY!
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
THIS CAN BE DONE ON ONE OF THEM MULTI-GADGET PHONES IN THEIR PARKING LOT!
LEMME KNOW HOW IT GOES....IMMA WAITING!
THE MEDIC
May 30, 2013 at 7:52 AM
