starting
125,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
PACHYAUTO63
  • 40 POSTS
The fuel pump is running and will crank but shut off when accelerator is pushed when starting.
Feb 7, 2018 at 1:47 AM
  • 110,248 POSTS
Nissan has had a lot of issues with the integrated power distribution module (IPDM). Basically, the IPDM is a glorified fuse/relay box located under the hood. I have attached a picture of it for you to see. Open the hood and locate the IPDM. Next, switch the ignition relay with another relay with the same part number to see if that makes a difference. If that does not work, try the same with the fuel pump relay. Note: These relays are usually all the same, but confirm the part number is the same on the ones you switch. Let me know if this helps. If it does, simply purchase a new relay for the faulty one. Additionally, the relay location within the box will be listed on the inside cover.
Feb 7, 2018 at 3:18 AM
