Cranks no start issue
196,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
WALLACE215
I cannot start my truck. It turns over but I can't get it to start. I checked the distributor cap the battery. I do not know what to do. please give me a couple options I can check myself. i am my own mechanic need transportation bad. thanks
Jul 26, 2019 at 7:21 AM
  • 110,248 POSTS
Have you checked for spark and fuel to the engine? Also, will it start for a couple seconds if you use starting fluid? Take a look through these links. The first discusses the most common cause of a crank/no start condition. The second two explain how to check fuel pressure and for spark. The last one explains how to retrieve diagnostic trouble codes from a Ford OBD 1 system. All you need is a test light.
and
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Let me know what you find.
May 31, 2021 at 5:46 AM
