Starting
2005 DODGE NEON
173,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
DODGENWW
  • 56 POSTS
Why do I have to give my car gas in the morning and through out the day depending on the last time I started it
May 7, 2016 at 10:13 PM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it.
Here is a link to an article from this site that features written instructions and pictures showing and explaining the process of checking the fuel pressure yourself. If you decide you would like do this yourself you can purchase a fuel pressure gauge from Amazon.com.
May 8, 2016 at 3:09 AM
DODGENWW
  • 56 POSTS
Fuel pressure is fine
May 15, 2016 at 7:15 AM
HMAC300
  • 48,601 POSTS
scan for codes if check engine light on and clean throttle plate on both sides with choke cleaner and iac hole.
May 15, 2016 at 8:26 AM
