Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Neon
Engine
Symptoms
Not Cranking Over
Will not crank
2005 DODGE NEON
17,200 MILES
RAMERMARK75
MEMBER
1 POST
The dash lights come on but will not crank over to start with the ignition.
Nov 5, 2018 at 5:19 AM
Experienced Mechanic
It sounds like the starter motor has gone out but to be sure lets run down this guide.
Here is the location for your car for the starter and a guide to help you walk through the steps.
Image (Click to enlarge)
Apr 15, 2021 at 11:44 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
