Starting
200,000 MILES • 0.6L • 6 CYL • 4WD • AUTOMATIC
CARRIEMORAIS
I have changed alot of parts, but I'm still having a lot of trouble starting it.
Brand new battery, starter, alternator, fuel pump its cranking, but not kicking over please advise.
Mar 7, 2016 at 12:48 AM
HMAC300
  • 48,601 POSTS
Scan for codes and check the fuel pressure with a gauge first. Most auto parts stores rent the gauge. Also, on this car check near rear stud on head for harness worn through not allowing it to start. if it is use solder connections and shrink tube and try to reroute harness away from the stud.
Mar 7, 2016 at 1:31 AM
CARRIEMORAIS
I can't get it started to take it in for a diagnostic, but could it be the fuel pump relay?
Mar 7, 2016 at 1:34 AM
HMAC300
  • 48,601 POSTS
Check fuel pressure, if power goes to pump then relay is good it only works for about 2 seconds on start up. See pictures on how to diagnose and get back to us with numbers. Also, make sure to check the harness.
Mar 7, 2016 at 4:19 AM
