Suddenly shut off and will not restart
200,000 MILES • 3.0L • V6 • 2WD
WATSON.STEVE
Car was idling fine in driveway. Then made a bad noise. Then shut off tried to start it back up. Nothing but clicking. Then tried to jump it made no difference.
Oct 8, 2020 at 1:41 PM
WATSON.STEVE
Also pulled belt off to make sure nothing was locked up. All pullies moved . AC/alternator/smog/even big wrench on crank.. Everything seemed freed up.
Oct 8, 2020 at 1:58 PM
Good morning,
The noise could have been the engine itself. There may have been a failure internally that made it stop.
https://www.2carpros.com/articles/engine-noises
Were you able to turn the engine by hand? Can you rotate it 360 degrees to be sure nothing is blocking it from turning?
Oct 8, 2020 at 8:52 PM
WATSON.STEVE
Didn't turn that much. Just a little bit with a wrench.
Oct 8, 2020 at 9:14 PM
Okay, thanks.
Sounds like something broke inside the motor.
Most likely you will need to replace the engine with a used engine to get going again.
https://www.youtube.com/watch?v=_VPgCQ42HiI
Oct 8, 2020 at 9:19 PM
