engine backfires
2002 FORD F-150
119,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
RICHARDQUINTO
when starting in the morning or if it sets for ten minutes the engine backfires through the manifold. After it starts it runs perfect no problem at all. If you park it for five minutes the same thing occurs. I have replaced the MAF , cleaned the pcv, fuel filter. Cleaned the throttle body and the IAC. After it starts you get a code P0171 and P0174. You can clear the code and it will not reappear until it starts again. Have any ideas?
thanks
Jun 26, 2017 at 6:29 AM
  • 55,433 POSTS
This is a lean system trouble code and is caused by too much air int he system which can be caused by two things, first is the engine misfiring.
the second is a vacuum leak.
Please run some tests and get back to us we are interested to see what it is.
Cheers, Ken
Jun 28, 2017 at 10:58 AM
