Intermittent not starting
201,111 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CHRISTOPHER IVAN ROEDER
  • 156 POSTS
So when I go to start the car usually after I just drove or stopped and turned the car off when I go to start it again it won't turn over and if I hit the gas pedal when I'm starting it then it'll fire up. becoming a nuisance. I was thinking maybe I have carbon build up. but not sure how to find it or where to locate the problem since I know it's not the battery or starter because I've recently replaced those components. any help would be greatly appreciated thanks in advance.
Aug 28, 2021 at 3:38 AM
SQM
  • 6,383 POSTS
Many times dirty components can give you starting issues. Like if you have a dirty mass air flow sensor. It can also be the distributor.
The mass air flow sensor can be cleaned. As well as the throttle body.
These items should be cleaned while performing tune up.
https://www.2carpros.com/articles/mass-air-flow-service
Is your check engine light on?
If there is an issue with a sensor, it can trigger the engine light.
Sep 2, 2021 at 6:10 AM
  • 156 POSTS
No, the check engine light is not on at the moment.
Sep 2, 2021 at 1:46 PM
SQM
  • 6,383 POSTS
See if you can follow this tune up procedure. It covers cleaning out the mas airflow sensor along with few other components.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Sep 2, 2021 at 2:22 PM
