crankshaft position sensor?
168,876 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
LWRDR123
  • 7 POSTS
Turns over won't start ,told it was crankshaft positioning sensor.
Oct 12, 2020 at 6:38 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The crankshaft position sensor is a different style for your car. Engine speed is determined by pick up coils that are built into your ignition distributor. I've attached picture steps below for distributor removal and replacement.
This guide can help as well:
Hope this helps and let us know if you have any further questions on this issue. Thanks for using 2CarPros.
Oct 12, 2020 at 10:08 AM
LWRDR123
  • 7 POSTS
So what your are telling me is it's the distributor that's bad ?
Oct 13, 2020 at 5:51 AM
DANNY L
  • 5,648 POSTS
Hello again.
If the symptom is your car is not starting there is an ignition coil located in the distributor underneath the distributor cap. I've attached a picture below with a part number and price from AutoZone auto part stores. Your vehicle does not have a conventional crankshaft position sensor. Hope this helps and let me know if you have any further questions about this issue. Hope this helps and thanks again for using 2CarPros.
Danny-
Oct 13, 2020 at 7:20 AM
LWRDR123
  • 7 POSTS
Thank you for your advice. the person I bought car from changed the distributor and had the plug wires in the wrong order. I corrected them and it starts right up now. thanks again
Oct 14, 2020 at 12:03 AM
DANNY L
  • 5,648 POSTS
Your welcome!
Glad to hear you found the problem and were able to fix. Hope you will use our site again in the future. Thanks again for using 2CarPros.
Danny-
Oct 14, 2020 at 3:01 AM
LWRDR123
  • 7 POSTS
Is the 2.2 motor in a Camry the same 2.2 motor in the Celica?
Oct 15, 2020 at 5:02 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, the 2.2L in the Celica and the Camry are both the 5S-FE engine. Hope this helps and thanks again for using 2CarPros.
Danny-
Oct 16, 2020 at 9:29 AM
LWRDR123
  • 7 POSTS
You are welcome. that answers my question. Thank you
Oct 16, 2020 at 11:19 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Glad to help and let us know if you have any further questions on this issue. Hope this helps and thanks again for using 2CarPros. Hope you will use our site again in the future.
Danny-
Oct 16, 2020 at 11:28 AM
LWRDR123
  • 7 POSTS
Have a 1999 Honda Civic 1.8 motor. starts up idles fine then idle goes down almost stalls then catches and goes normal again. repeats cycle continuously. I am baffled. help please! thank you
Oct 23, 2020 at 6:14 AM
RENEE L
  • 1,260 POSTS
Hello LWRDR123,
In your question above you are asking about a different vehicle and issue. Can you please start a new question? For the site to properly index questions they need to about one issue/vehicle otherwise people will not be able to find the answer to that question under a different subject. The site is here to assist those that need direct help and, also provide a resource for others that have the same issue.
For your convenience here is the link:
Make sure you are logged into the site before clicking on the link.
Thank you for using 2CarPros and have a great rest of your day!
Renee
Site Editor
Oct 23, 2020 at 10:35 AM
