Starter wiring diagram needed?
20,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
MIKEHIL420
Putting a starter back in that someone else took out need help figuring out where the wires go. There's 4 of them. The purple wire that's supposed to go to the signal post has been spliced into another purple wire. The whole thing under there don't make sense to me.
Nov 28, 2024 at 6:36 AM
  • 110,248 POSTS
I attached the wiring schematic below. I see three wires. The heavy gauge wire from the battery directly to the starter, then from the same post on the starter, you have a wire that will lead to the alternator.
The third wire (purple) is the trigger wire. It is smaller in diameter and goes to the smaller post on the starter.
Take a look at the schematic below and let me know if it helps. Also, if it doesn't, I need to know the wire colors you presently have.
I had to cut the pic in half to make it readable. I did overlap the two so you can follow from one to the next.
Nov 28, 2024 at 11:21 AM
