Starter will just spin and will turn the motor
25,000 MILES • 2.8L • 6 CYL • 4WD • AUTOMATIC
SIDNEY TAYLOR
I put a new starter on it and it started one time and then started would just spin the next time.
Dec 25, 2018 at 11:37 AM
  • 110,248 POSTS
Based on your description, either the Bendix isn't engaging the starter and flywheel, which is unlikely if it is doing the same thing as the old starter, or there are problems with the teeth on the flywheel allowing the starter to spin without engagement.
What I suggest is to disconnect the battery and remove the starter. First, inspect the flywheel from where the starter is placed. See if the teeth or gears are damaged on the flywheel not giving the starter a place to engage. If they are good, bench test the starter to confirm the Bendix kicks out when the starter is powered. If it doesn't, you got a bad starter.
Dec 25, 2018 at 2:08 PM
