Will not start
236,000 MILES
NELLA37
First noticed over a period of time mpg decreased, then one day engine started missing and quit and will not crank. fuel pressure at rail but no spark. high mileage but engine still strong. I replaced crankshaft position sensor but still no start.
Jan 7, 2018 at 11:45 PM
  • 55,721 POSTS
Can I ask if the security light is flashing? If so then this guide will help.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If not then we need to run codes here is a guide to help.
If no codes are present then I would check the ENGINE MANAGEMENT RELAY (L). There are also 5 fuses that run the system lets check those as well.
Check out the diagrams (Below)
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Jan 9, 2018 at 6:24 AM
NELLA37
Will not run. Replaced crank position sensor and ignition control module . Turns over but will not run. Has fuel to rail but no spark. Any ideas or solution?
Jan 31, 2018 at 4:27 AM (Merged)
  • 55,721 POSTS
Did you check the fuses?
