starter spinning but wont start
180,000 MILES
NOODLEZ84
When I turn ignition, the starter spins but doesn't keep contact with flywheel. Had been hard to start but would start after a couple tries.
Apr 14, 2013 at 7:35 AM
JDL
  • 16,098 POSTS
Some gm starters use shims to properly position the starter. Also, check the flywheel teeth. Have you had the starter tested? Some of the national brand autostores will test the starter for you if you take it off and take it to them.
Apr 14, 2013 at 8:04 AM
