Starter solenoid replacement
104,000 MILES • 4.1L • V12 • TURBO • 2WD • AUTOMATIC
LAURA PERRY
My engine will not crank over. I was able to jump start the solenoid by using a screwdriver but that did not last long. How can I remover the top starter bolt without taking off the whole manifold? Is there an easy way to remove the starter solenoid?
Mar 26, 2018 at 2:36 AM
  • 55,732 POSTS
v12? tubro? Can we double check this? if it has the regular engine this is a guide that will give you an idea of what you are in for when changing the starter motor out.
Here is the diagrams shown from the manual for your car (below).
Check out the diagrams (below).
Cheers, Ken
Mar 27, 2018 at 5:39 AM
