Starter solenoid connections
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOE DURST
I've replaced starter and putting it back together and have a wire that I didn't notice during removal. I believe it attached with the command on the terminal with the battery feed because it was the only nut I removed. It is the same wire end at the battery feed and I'm guessing it is a feed positive feed to the harness; it is heading toward the passenger side and up.
Jun 29, 2019 at 6:59 AM
Without seeing a picture, you sound correct. Here are the instructions on the starter. It appears they list 4 wires/connections total.
Let me know if you need assistance. If you can submit a picture of this wire, it may help in identifying.
Thanks
Jun 29, 2019 at 7:49 AM
JOE DURST
Yes, I see the wire in the picture that I was blocked from seeing.
Thanks for the prompt and strong response.
Jun 29, 2019 at 8:44 AM
You got it, Joe. Come back when you have more questions. Tell a friend or ten!
Jun 29, 2019 at 8:50 AM
