2014 Honda Civic Starter Replacement
60,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
SPARKEV
  • 10 POSTS
I'm looking for detailed instruction on how to replace the starter. I've replaced starters on older cars and if it's not too complicated. I'll be replacing one on this car listed above.
Sep 10, 2020 at 8:24 AM
As requested. Here are the instructions from the manual. Let us know if you need more info. Thanks
Sep 10, 2020 at 9:09 AM
SPARKEV
  • 10 POSTS
Thank you!
Sep 10, 2020 at 9:29 AM
You are welcome. Please come back to 2CarPros in the future if you have other questions. Thanks
Sep 10, 2020 at 12:25 PM
ALFRED HILL
  • 7 POSTS
I cannot get to my starter to check things.
Jan 22, 2021 at 5:22 AM (Merged)
HMAC300
  • 48,601 POSTS
if it is not starting and you have a known good battery try resetting security system. See the link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
if starter is bad see pictures for removal.
ALFRED HILL
  • 7 POSTS
I want to know what I have to take apart to get to the starter as it is buried on back side of engine. everything is in the way.
CJ MEDEVAC
  • 11,000 POSTS
Did you click on the pictures that HMAC300 provided above?
The Medic
ALFRED HILL
  • 7 POSTS
The picture just shows how starter comes out. I need to know-how to get to the starter, as the manifold is hiding it. The pictures do not show that .
HMAC300
  • 48,601 POSTS
if you would read the instructions on the picture it tells you everything to remove starter.
ALFRED HILL
  • 7 POSTS
Yes it tells how to remove starter, but what do you have to take off to get to the starter? The manifold is blocking it at the top.
HMAC300
  • 48,601 POSTS
if you follow the steps you should be able to do this. this was taken form a 1.3L Honda as it does not show a 1.2L. try from bottom if this is not sufficient I apologize as this is all we have.
Jan 22, 2021 at 5:23 AM (Merged)
CALLIE02
Trying to remove and replace starter. Does anyone have a step by step picture of how to do this?
Thank you,
Brenda
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Here are the instructions on how to remove this starter: Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Here is the location in the diagrams below. Please let us know if you need anything else to fix it.
TORA_SEGEUL
Where is the starter located and how do you change it?
ED-WEEZY21
  • 248 POSTS
Here is a guide that will show you how to change it out with a diagram below to show you the starter location.
MATTHEW FOX
I have a new starter and I am ready to install it. Is it easier to go from under the car or take the intake manifold off and just work up top?
HMAC300
  • 48,601 POSTS
see pictures for removal and reverse for install. make sure to remove knock sensor for easier access and not to break it. also remove negative battery cable prior to beginning.
ALFRED HILL
  • 7 POSTS
Not enough info... what do you take off after taking manifold brkt off ? Does the manifold come off ?
  • 55,691 POSTS
Hi ALFRED,
No the manifold stays on, you only take off the manifold to gain access to the starter.
Let me know if you have any other questions.
Best, Ken
SCOTTYMC
how to remove starter from 1.8 2007 honda civic ex
SATURNTECH9
  • 30,869 POSTS
Starter Removal and Installation
Removal
1. Make sure you have the anti-theft code for the audio system and the navigation system (if equipped), then write down the audio presets.
2. Disconnect the negative cable from the battery first, then disconnect the positive cable.
3. Remove exhaust pipe A.
4. Remove the intake manifold bracket.
5. Remove the harness clamps (A) and harness connector (B) from each clamp.
6. Remove the two bolts securing the starter, then remove the starter from the engine.
7. Disconnect the starter cable (A) from the B terminal. Disconnect the connector (B) from the S terminal, then remove the starter.
INSTALLATION
1. Install the starter cable (A) and connector (B). Make sure the starter cable crimped side of the ring terminal faces away from the starter when you connect it.
2. Install the starter, then loosely install the upper mounting bolt (A) and lower mounting bolt (B).
3. Tighten the upper mounting bolt, then tighten the lower mounting bolt.
4. Install the harness clamps (A) and harness connector (B) to each clamp.
5. Install the intake manifold bracket.
6. Install exhaust pipe A. Use new gaskets (B) and new self-locking nuts (C).
7. Connect the positive cable to the battery first, then connect the negative cable.
8. Start the engine to make sure the starter works properly.
9. Enter the anti-theft code for the audio system and the navigation system (if equipped), then enter the audio presets.
10. Set the clock.
JUST ROSIE
Hello, my mechanic is replacing my starter for me. He just called and let me know that he cannot put the new the starter in without taking off the axle. I knew the starter in this car was complicated to get to, but is it that complicated? It just seemed a little odd to me, I was wondering if anyone knew. He said "between the block, plastic (plenum?) that wraps around behind the engine and that axel". I know absolutely nothing about cars so I just want to make sure this does not sound odd.
Thanks in advanced!
STEVE W.
  • 15,404 POSTS
Well it is tucked in pretty good. It is almost directly over the axle. I recall that you need to drop the right tire off and an exhaust pipe to get room to work. But I do not think you have to pull the axle to get it out. It may be that he wants more room to work. Hard to say.
If you search youtube with "starter motor 2007 Civic" you can see the process. But as I said he may want more room to work.
Suggested Repair
Disconnect the battery, negative cable first, and have the audio anti-theft code ready. Access the starter from below: remove exhaust pipe A and the intake manifold bracket, but leave the manifold installed. Disconnect the harness clamps and starter wiring, then remove the starter bolts. Dropping the right tire and exhaust can improve working room; axle removal is usually unnecessary. Reinstall in reverse using new exhaust gaskets and self-locking nuts, then verify that the starter operates.
Conversation Summary
The owner of a 2014 Honda Civic asked for starter replacement instructions, and later users asked how to reach a buried Civic starter, including a 2007 1.8L model. Experts said to disconnect the battery, remove the exhaust pipe and intake manifold bracket, disconnect the harness and starter wiring, and remove the mounting bolts. They clarified that the manifold itself stays on and that the starter sits near the axle, so extra room may help, but pulling the axle is generally not required.
