starter replacement
200,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
LYNN STREIF
I have the old starter out and the new one in, but I can't get the nut on the back bolt. Any ideas?
Dec 31, 2019 at 1:51 AM
BMDOUBLE
  • 1,139 POSTS
It is a very awkward starter to replace to say the least! Are you having issues starting the nut on the stud or just reaching the stud because of the limited space? It's a total feel type of situation because of the limited space for sure! Removing the vacuum hose from the side of the intake can give you a little extra room as well. I have extra long skinny fingers and arms so I have done it without issue, but it can still be a pain. Try running the bottom bolt all of the way in so the start isn't flopping around and feel for the stud first to get your hand familiar with the location then go in with the nut very slowly and carefully while holding your tongue just right and you should be able to get it going! (just kidding about the tongue lol). Good luck!
Dec 31, 2019 at 2:15 AM
