How to remove the starter?
153,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
TJMOWBRAY
  • 85 POSTS
Starter removal.
Nov 14, 2024 at 10:26 AM
  • 110,248 POSTS
I attached the very vague directions from my manual for replacing it below. See pic 1 below. As mentioned, they are vague, so here is a link that explains in general how to replace one. It should help give you a better visual.
Before you start this job, make certain the battery negative is disconnected.
Let me know if this helps.
joe
See pic below.
Nov 14, 2024 at 12:30 PM
  • 55,627 POSTS
Can you tell us happen with this?
Apr 29, 2025 at 5:04 AM
