I've attached a picture below of your vehicles starter. It looks like only held in with 2 bolts.You might need a screwdriver or pry bar to wedge it loose.Hope this helps and thanks for using 2CarPros.
Danny-
Image (Click to enlarge)
Sep 10, 2019 at 5:02 AM
RLOPEZ8196
MEMBER
Okay, did everything in the tutorial car started up fine, but now it's taking awhile to start up. Is there anything else besides the starter that will cause this problem??
Sep 13, 2019 at 4:32 AM
✓Experienced Mechanic
Welcome back:
When you say it is taking longer to start, can you explain what is happening? For example, is there a delay before the starter engages or does it seem to crank longer?
