Starter Relay location needed?
3,600 MILES • 1.4L • 4 CYL • 2WD • MANUAL
JLSII
Hello, I have a Versa-S, 5sp Manual Transmission. I'm trying to locate the Starter Relay for this car, but I can't find it, I want to add a "Shut off Switch" on this car. I hope you can help? Thank you. Jerry S.
May 23, 2025 at 5:41 AM
  • 55,721 POSTS
It is called a "Starter Cut Relay" which is inside (built in) the IPDM under the hood on the left side of the engine bay. You will need to do some digging to get to it. I would interrupt the starter trigger wire (small red) instead.
May 23, 2025 at 6:00 AM
