Now the engine cranks but does not start?
16,700 MILES • 6 CYL
RICK87121
Had a bad starter replaced it but I tried to take off the relay and broke the top casing. Now the car cranks but doesn't start. I bypassed relay now cranks and no start. Also check engine light does not come on and windows doesn't work. Did I ruin my relay and is it multi-functional?
Sep 6, 2022 at 4:40 AM
  • 55,694 POSTS
There are two fuses associated with the starter system that need to be checked, the first is AM2 30 amp in the under-hood relay fuse panel and the other is AM1 5-amp fuse in the left side of the dash fuse panel.
Here is a guide to help and thew starter wiring diagrams so you can see how the system works:
Sep 6, 2022 at 11:11 AM
RICK87121
I have changed the blown fuse for the starting system, but it is still cranking and not starting. Before the starter went out, I didn't have any issues. It always started on the first try. Any ideas?
Sep 8, 2022 at 6:40 AM
  • 55,694 POSTS
Will the engine run if you use starting fluid? Can you hear the fuel pump run in the tank for about 5 seconds if you turn the key on but don't crank the engine over?
This guide can help:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over this guide and report back.
Sep 9, 2022 at 10:31 AM
