Starter relay
30,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
ODEEK999
  • 7 POSTS
Hi, great truck. Decided to replace a clicking starter relay. Did not place leads back correctly. Small spark then nothing. No smells-no burning. Re did the wires as I thought that I had remembered. Now it turns over just fine then runs for one to two seconds and shuts off as if it is getting no gas. I should never have messed with it in the first place as I am very much a novice, old, disabled, and poor. I am not so interested in fixing it as I already made that mistake. But can you guess as to what I broke? Thanks so much!
Jun 23, 2018 at 3:42 AM
CJ MEDEVAC
  • 11,000 POSTS
Does it only run while it is cranking? (or does it run after you release the key?)
Is anything else not working?
Have you checked your fuses?
The Medic
Jun 23, 2018 at 9:23 AM
ODEEK999
  • 7 POSTS
One does it so many thousands of times I am not sure what I was doing with key. I think after it cranked and caught and tried to run for a second then shut off I then released the key completely like you normally would when trying to start a cold engine. I pumped the throttle for the second that it almost ran which did no good-it is efi. All power worked the entire time, not even any dimming. I briefly checked the fuse panel and did not see any broken elements. However, one of the small leads that connected to one of the large posts had an inline fuse but it was sealed. I am sure that of the three smaller leads I just attached one of them to the wrong relay post. Two leads went to the negative (starter) post along with the negative large battery cable, and one lead went to the positive battery post on the relay along with the heavy positive battery cable. Three leads (there is one other small lead that is coated and goes to the threaded tiny post on the relay even I cannot mess that one up) plus the two battery cables to two threaded posts on the relay. One of those smaller ones I connected to the wrong relay post but I do not know where it went and what it messed up. I am sorry. Can you make any sense of this?
Jun 23, 2018 at 10:25 AM
CJ MEDEVAC
  • 11,000 POSTS
This is a picture of an 1987.
The starter cable is always all by itself on a fat terminal.
The positive battery cable and anything constantly requiring 12 volts are all stacked together on the other fat terminal.
"S" wire snaps onto the little terminal, the little terminal is normally labeled as "S" on the solenoid body.
The other little terminal is "I", if it is used (sometimes it is not) , it feeds back to the coil to sort of boost its power (full battery voltage)while the starter is robbing battery power from it. It shuts off as soon as the the key is released from the "start position".
Are you wired up like this?
The Medic
Jun 24, 2018 at 7:06 AM
ODEEK999
  • 7 POSTS
Kind of helped but I have just three terminals, two fat ones (one for positive battery post plus one loop ended smaller wire that I do not know where it went; and the other fat post was connected to the battery post that went down to the starter along with two loop ended (metal connectors) smaller wires that I do not where they went. And then one small, threaded silver (not copper) post that was connected to a rubber coated snap on wire that, again, I do not know where it went. When I crossed one of those three looped smaller wires and placed it on the wrong fat post I think that is what caused the spark and I think screwed up wherever it was supposed to go. When I switched one of those three smaller wires and put it on the other post that is when the motor turned over and ran for a second. When it shorted I must have damaged wherever the wire was supposed to go as if the ignition was now burned, or if one of those smaller wires was supposed to trigger something having to do with the fuel supply. I know I cannot make it really clear. I had it towed to the garage and hopefully tomorrow I will learn what the problem is. If you are interested I can write back to this address and tell you what it was.
Jun 24, 2018 at 8:38 AM
CJ MEDEVAC
  • 11,000 POSTS
The one fat post is the starter wire only!
The rubber elbow one goes on the little "S" terminal (only place it can go!).
Everything else stacks on the other fat post with the battery cable.
Unless;
You had a ground wire as in my picture, hook it to ground.
Only you can remember if this was the case.
Once it hooked up right, do you have power where you are supposed to?
Another picture below.
The Medic
Jun 24, 2018 at 12:15 PM
ODEEK999
  • 7 POSTS
It looks like your picture except I do not have the upper wire where the black arrow is-it does not exist. If that ground is attached to one of the sheet metal screws that holds the relay to the fender it is not there no wires go to those two anchoring screws. In the directions which I, unfortunately, just glanced at it says to make sure that the fender wall and back of the relay are really clean as that is the ground. On mine the starter wire was not the only wire attached to the fat post-there are two smaller wires also, so three wires in total to the negative fat post and two wires to the positive post. I do not know where you are and how late it is but I will try to quickly find a picture representing mine on a Google image search.
Jun 24, 2018 at 12:40 PM
ODEEK999
  • 7 POSTS
Did this come through?
Jun 24, 2018 at 12:49 PM
CJ MEDEVAC
  • 11,000 POSTS
Roger on a picture.
The solenoid does not have a positive and negative post!
It has a post in which the positive cable connects to.
The other post (for the starter) is dead, but becomes "positive" too, when the solenoid activates. This temporarily makes the starter turn/ crank until you release the key.
If you put anything else on the starter side, it will only get powered while you are cranking the vehicle, then it will shut off when you release the key.
Only the starter, by itself, should be on the other fat post. (it really does not matter which post)
Anything else requiring energy should be stacked with the battery cable on the opposing fat post from the starter.
Just read yours, modified your picture.
Return with good news!
The Medic
Jun 24, 2018 at 1:10 PM
ODEEK999
  • 7 POSTS
Okay, I just called them negative and positive because those are where the cables were received from the battery. If I knew I was using the wrong terminology I probably would not require any help, lol. Thanks for all of your effort. We still do not know what was damaged though. I will let you know hopefully tomorrow. It cranks though but when it runs for a second (I think at that point I have released the key) then it stops just like it is getting no fuel. Oh well, as long as it does not cost me hundreds of dollars I will be okay and will finally stop fiddling with things I know nothing about! But I thought this would be simple and it would have been if I had just hooked it up as it had been originally. Or better yet, I do not think there was anything wrong with it but I have had this truck for over thirty years and periodically I just feel like putting something new in it. Stupid
Jun 24, 2018 at 1:27 PM
ODEEK999
  • 7 POSTS
Well, you were right. One fat post on the relay should only have had one connection-the heavy starter cable. All others went to the other fat post including the positive battery cable. Took him five minutes to fix it and charged me nothing. Thanks again.
Jun 25, 2018 at 3:30 AM
CJ MEDEVAC
  • 11,000 POSTS
Looks like you owe me lunch! LOL!
You could of been running last night!
Glad you got him fixed, come back to see us, but this time with a Jeep CJ. I will have you 100% covered on one of them.
Thanks!
The Medic
Jun 25, 2018 at 8:24 AM
