Where is the starter relay located?
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
  • 239 POSTS
Trying to locate the starter relay if any or its the main relay that powers the starter.
Jul 30, 2021 at 2:25 PM
SQM
  • 6,383 POSTS
The starter relay is located on the fuse box left side of the dash (see diagrams below). I have also included all of the fuse block diagrams for your reference.
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
Jul 30, 2021 at 3:18 PM
  • 110,251 POSTS
There is a starter relay. It's located under the dash on the left (driver's side). First, I attached the starting system schematic for your vehicle. There was only one pic, but I had to cut it in half to make it readable. I did overlap it so you can follow from one to the next.
The next pics show the location of the relay.
If you suspect the relay is bad, here is a link that explains how to test one.
Jul 30, 2021 at 3:28 PM
PACIFICISLANDER
  • 239 POSTS
Thank you so much Gentlemen sure appreciated. Followed the EWD and it end up with P/N switch being the culprit, Now it's time to hit the road
SQM and Joe, thanks and take care.
Jul 30, 2021 at 6:49 PM
SQM
  • 6,383 POSTS
You're welcome.
Thanks
Jul 31, 2021 at 1:52 AM
