Thanks for visiting 2CarPros. it sounds like you may have been applying voltage to the field wire on the solenoid. this would cause it to just spin.
What you want to do to test the starter is apply voltage at the large post of the solenoid and at the S terminal.
The other small terminal is the R terminal and is not used on this model.
There should not be a relay. Power comes from the ignition switch via a yellow wire, to the clutch switch if manual or neutral switch if automatic and goes to the solenoid as a purple wire to the S terminal.
If you have 12 volts at one side of the clutch switch or neutral switch and non on the purple wire with the clutch pushed or transmission in neutral then the switch is bad.
The below guide explains how to measure voltage:
I'll also post a picture below explaining the starter terminals.
Jan 6, 2019 at 11:23 AM
