starter problems
DAVID COUNCIL
i put a new starter on my truck. it started a few times and then it quit starting. and i could not stop the starter drive from striking the flywheel no matter how i shimmed it. could it be the ignition switch on the base of the column.
Apr 16, 2013 at 5:28 AM
JDL
  • 16,098 POSTS
Did you examine the flywheel? The teeth are good, no cracks on the flywheel/flexplate anywhere? Was it the proper starter? It's hard for me to tell much without being able to look at it.
Apr 16, 2013 at 5:44 AM
