Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Windstar
Engine
Symptoms
Not Cranking Over
Starter problem will not turn over
2001 FORD WINDSTAR
1,970,000 MILES • 3.8L • 6 CYL
GERALD SNYDER
MEMBER
1 POST
Start Bendix engages but will not turn over.
Mar 6, 2017 at 8:23 PM
HMAC300
Experienced Mechanic
if engine can turn over by hand then you probably need a starter or something wrong with flywheel like teeth worn off. You will be able to tell when starter is out. but more than likely starter drive is bad.
Apr 6, 2021 at 12:12 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
