Starter problem will not turn over
1,970,000 MILES • 3.8L • 6 CYL
GERALD SNYDER
Start Bendix engages but will not turn over.
Mar 6, 2017 at 8:23 PM
HMAC300
  • 48,601 POSTS
if engine can turn over by hand then you probably need a starter or something wrong with flywheel like teeth worn off. You will be able to tell when starter is out. but more than likely starter drive is bad.
Apr 6, 2021 at 12:12 PM
