Starter problem
213,000 MILES • 4.3L • V8 • 2WD • AUTOMATIC
JIMMY RAV
I have a 3500 series van. I have gone through several starters and two fly wheels. the starter keep kicking back. It has broken bother starter bolts. I thought that it may be ignition problem causes the fly wheel to kick back upon staring. I did a full tune up and everything was fine for about an hour, then right back to grinding. This starter has to be moving somehow. any guesses?
Apr 9, 2018 at 1:49 AM
CJ MEDEVAC
  • 11,000 POSTS
Is this a 4.3? I show a 5.7L, 7.4L, and a 6.5L Diesel for a 3500 Express.
Maybe this is a type-o (you or me) or you have the wrong parts?
Continuing,
Have you tried starter shims?
The block surface and starter housing surfaces may be too close together (factory machining). This would make the starter gear and flywheel gears be too close together. Even if it gets thrown in and turns, the gears would be in a bind. Shimming the starter down some might solve the problem.
Sometimes trying another brand of starter might solve the problem (if you have not already).
Your turn,
The Medic
Apr 9, 2018 at 11:12 AM
