Starter only starts when engine is cold
104,089 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
CONNIE WILLIAMS MANARY ROBINSON
My car is having an odd problem. When the car is cold or has only been driven a few miles or few minutes it starts up without hesitation. New battery just installed. Now two times after driving the car like thirty to forty minutes once it is turned off it will not start until the engine has completely cooled down. several hours later. Then boom starts. The engine does not register hot, but it does have a different smell sometimes. Just had the oil changed too. All fluid levels are fine. What could cause this?
Oct 21, 2017 at 2:37 PM
  • 31,937 POSTS
A dealer can look further into this problem with the factory IDS scanner, they can pin point individual sensors and check out puts that can affect the PCM. i would be interested to see what the coolant temperature sensor is doing. i think that this may be the only way to get to the bottom of this problem.
Oct 21, 2017 at 6:18 PM
