Starter not working
150,000 MILES • 2.5L • 5 CYL • 2WD • MANUAL
JEFF VAN PELT
Headlight not working, so I checked fuses. now everything works but starter won’t engage. battery good, voltage good, voltage at starter. pulled fuses to look at them.
Jun 19, 2019 at 1:09 AM
  • 55,732 POSTS
When you turn the key to crank the engine over is the security light flashing? If so please follow this guide to reset the system.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If not it sounds like the starter has gone out but to be sure lets run down this guide.
Jun 20, 2019 at 7:27 AM
