starter makes a bad noise sound like the starter Bendix not engaging into the fly wheel
188,000 MILES • 2.8L • 6 CYL • RWD • AUTOMATIC
JOE1953
  • 809 POSTS
when turn the key to cranking the the starter makes a bad noise sound like the starter Bendix not engaging into the fly wheel. but when I keep on cranking it will turn the engine. what is causing this problem?
Sep 27, 2016 at 12:39 PM
CARADIODOC
  • 34,414 POSTS
Typically the starter drive is not locking up intermittently, but it is also possible to have some worn teeth on the ring gear. The starter must be removed to inspect the teeth on the ring gear, but even then it can be hard to tell because only the front part of a few teeth are worn away. Engines often coast to a stop in the same orientation causing the starter drive to initially engage with the same teeth on the ring gear over and over.
Sep 27, 2016 at 1:13 PM
JOE1953
  • 809 POSTS
what i need to do to remove the starter and how long it take to remove the starter?
Sep 27, 2016 at 1:40 PM
CARADIODOC
  • 34,414 POSTS
My memory is not good enough to answer that. Your best bet is to get a copy of the manufacturer's service manual. Normally I do not like to recommend Haynes or Chiltons manuals, but for this job they would be okay. You can usually find a good selection of them at your public library.
Sep 27, 2016 at 2:07 PM
RENEE L
  • 1,260 POSTS
Hello JOE1953,
Here is a link that will be of help to you finding a manual.
https://www.2carpros.com/manuals/manuals.php
If you have any other questions please come back to the site and thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Sep 28, 2016 at 8:38 AM
JOE1953
  • 809 POSTS
i didn't see much wrong with the teeth but the stsrter drive wasn't locking up it was bad so i replace the starter and it working good.
Sep 28, 2016 at 9:06 AM
CARADIODOC
  • 34,414 POSTS
Dandy. One in a row! Happy to hear it's solved.
Sep 28, 2016 at 5:38 PM
